andstef Posted March 11, 2016 Share Posted March 11, 2016 Hello everyone, I'm having some trouble with vray fur. I'm trying to recreate a reed roof, as you can see in the attached image. The results are what i expected, except for a small annoying detail. When the image renders, some buckets render different from the rest. The settings are as follows: scene units: cm display units: cm vray fur settings: lenght: 15cm thickness: 0.6cm other setting in the attached screen capture I tried rendering with low, and high settings and the issue persists. I hope someone can help. Thank you Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted March 13, 2016 Share Posted March 13, 2016 Are you rendering with several nodes, or just on one computer? I seem to recall others with similar issues solved them by making sure all of their render nodes had access to all the maps required to render the scene, so your problem might be similar, but i really have no idea though. Link to comment Share on other sites More sharing options...
andstef Posted March 14, 2016 Author Share Posted March 14, 2016 I am rendering with one machine, and there is no warning about missing maps. Link to comment Share on other sites More sharing options...
