andrewsutton Posted March 27, 2016 Share Posted March 27, 2016 Hello, Worked as a designer, with graphics programs, there is a backup of all your graphic projects, one of them refused to open in AutoCAD 2015. I tried to open the project on several machines, the result is the same, an error pops up: "Internal Error !dbqspace.h@410: eOutOfRange" I do not know whom to contact and what to rebuild the project, time is running out. Thanks in advance. Link to comment Share on other sites More sharing options...
kaydenfletcher Posted April 8, 2016 Share Posted April 8, 2016 If a file can be opened but still shows signs of corruption, take the following steps or see and learn next topics about AutoCAD file corruptions, moreover the last solution can help you if your file was severely damaged by unknown reason http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016/how-to-recover-autocad-autosaved-files/td-p/5385925 https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/documentation/ACD/2014/ENU/files/GUID-353D7074-378B-401E-A983-B2E6C1930264-htm.html https://dwg.recoverytoolbox.com/ Recovery Toolbox for DWG If a file cannot be opened, take the following steps: • RECOVER command --Recovers a selected drawing file --If successful, open and run AUDIT command --Evaluates drawing integrity and possibly more error correction --Set system variable AUDITCTL=1 to create a report of audit results • RECOVERALL command (introduced in AutoCAD 2008) --Recovers a selected drawing file --Attached and nested xrefs are also opened, repaired, resaved, and closed • INSERT and EXPLODE • Start a new DWG with no template --Run INSERT and selected the corrupted drawing --Check the “Explode” option Link to comment Share on other sites More sharing options...
