Win 10 not handling 3ds max
fattonyrends
Hello there,
Recently purchased windows is not handling 3ds max. It keep crashing while rendering.
I increased virtual memory to 3 times more than actual (32 GB ) and it keep crashing.
Windows ,3ds max and Vray are properly purchased.
Thank you for any input.
Stefan
The problem is that officially there is still no support from autodesk on windows 10. So even autodesk is saying that is might not be 100 % compatible with win 10. I am just trying to understand what might be the problem before downgrading to lower win.
Do you use a 32 GB swapfile or even meant you have the size increased to 96 GB ? ( 3 x 32 GB )
I would recommend reducing the swapfile to the bare minimum, even when windows recommends otherwise
Lock the swapfile size by setting minimum/maximum the same value
If you ever see your RAM being eaten up to its limits during rendering, buy more RAM, don't rely on the OS paging out to the swapfile
I use only a fixed size of 4GB, though i never come near the machines hardware RAM limit which is 32GB too
And rendering ( i guess MR ? ) is the least likely module to cause troubles with a new OS, more likely are UI, input and viewport glitches
And Autodesk ( and other software companies ) always take a over-cautious position when making public statements about compatibility, especially with new OS'es
Edited by spacefrog
