liorsturlesi Posted April 6, 2016 Share Posted April 6, 2016 Hi, I'm working on an animation and want the output frame buffer to give me follow numbered names for the saved frames, for example - frame001, frame002,frame003 and so on.. Is it possible ? Thank you. Link to comment Share on other sites More sharing options...
John Dollus Posted April 6, 2016 Share Posted April 6, 2016 if you need custom frame padding, you can use a file renaming utility to remove a single character within the file name string to do what you need. http://www.filerenamer.net/ (ie. in the file renamer, specify to remove 1 character after the first 5 in your given string (frame0001 would then become frame001) I could have sworn there used to be a field for specifying the frame padding within max but that may have been ages ago and it's since been removed. why do you need custom frame padding? Seems odd to limit any animation length to 999 frames. Link to comment Share on other sites More sharing options...
liorsturlesi Posted April 10, 2016 Author Share Posted April 10, 2016 thank you john Link to comment Share on other sites More sharing options...
