kentchuang Posted April 7, 2016 Share Posted April 7, 2016 Hey guys, as the title states this warning is popping up on the render. And as a result I am getting a completely messed up rendering. Here is picture attached. Anyone have any idea what's going on? (Vray 3dsmax) Cheers Kent Link to comment Share on other sites More sharing options...
kentchuang Posted April 7, 2016 Author Share Posted April 7, 2016 Also, every material applied is a vray material. Link to comment Share on other sites More sharing options...
John Dollus Posted April 7, 2016 Share Posted April 7, 2016 what happens when you use an override material? Link to comment Share on other sites More sharing options...
kentchuang Posted April 7, 2016 Author Share Posted April 7, 2016 Now im starting to think it may have something to do with the settings. This is how it comes out with no materials applied. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted April 7, 2016 Share Posted April 7, 2016 Check that there is not Autodesk materials in your scene, simple way is using material overwrite. From the first screen shot, it seems that you have some Autodesk material there. Second it seems there is not GI? not related to your problem, but just saying. Last but not least, be sure the box for Force color clamping is active in your VRay buffer. Link to comment Share on other sites More sharing options...
kentchuang Posted April 8, 2016 Author Share Posted April 8, 2016 Im currently rendering another project with Autodesk materials applied to it, and it doesn't show up with this error or this early microsoft windows graphics.....I guess it must have something to do with that specific project and the settings.....But I can't seem to think of, or find any deviations to the settings. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted April 8, 2016 Share Posted April 8, 2016 Convert all materials in scene with this: http://www.motivacg.com/en/material-converter/ Then try rendering. This will at the very least rule out the materials being a problem. Link to comment Share on other sites More sharing options...
kentchuang Posted April 8, 2016 Author Share Posted April 8, 2016 Thanks a lot Chris, that script seemed to have fixed the issue. Cheers ! Link to comment Share on other sites More sharing options...
