Alpha Channel Accuracy
christosviskadourakis
Hello there.
I want to use my alpha channel to change the background of my rendering. However, I found out (later in photoshop) that the accuracy of the alpha channel is not that great. I had to manually refine the edges of the alpha channel image, otherwise there was a white outline on the final image. The problem was more obvious on the areas that I have vegetation (trees) with opacity maps for leaves. But it was actually everywhere. For instance, on the edge of a wooden fence.
Any idea how to avoid this? Thank you!
Christos
If you are using a vray dome light with an HDRI just make that light invisible and be sure the max environment background is black.
If you are using an HDRI directly into the max environment background map clear it from there and use it in the environment tab inside vray settings.
The idea is to use a black color as background in max.
