GPU upgrade 3ds max?
Hello,
I'm currently using over dated gtx 570 for my work in 3ds max 2014. Its a bit slow in scenes with a lot of instances and editing high poly models (large architectural scenes). I also run HWmonitor to check actually how much utilization gpu has - max util is around 22%.
When i can im using proxies, but sometimes i have to change a bit in a model and then proxy is a pain ita.
I had also tried tial of 3ds 2016 - even worse in my situation.
Please share your experience in upgrading your gpu Geforce or Quadro.
Im interested only in viewport performance since im using corona for rendering purposes.
My setup:
cpu i7 3770k - 4.6ghz
32 ddr3 1333
gtx 570 1280mb
2ssd raid0
  • 2 weeks later...
I've done some research and figured out that there's no need to buy high end gpu for max.
I was considering k2200 vs gtx970 (cheaper choice) So I think I'll go with gtx 970 as my old 570's capacitors already started to squeak.
My models are around 30mln polys but sometimes starts to slow down even with 10mln.
I'm willing to spend more, but only if there will be significant improvment over gtx970.
Do you think its a good buy?
