Problem when chamfering edge
shineugene
Hello
I am trying to create a kitchen sink. I have the general shape completed but I want
to chamfer the front edges of the kitchen top to give it a round edge. But I have
run into a problem with chamfer. The right side gets chamfered properly with 4 sections, as intended but the left side doesn't get chamfered properly. I have attached a jpeg image.
As you can see, the left side of the chamfering doesn't get rounded out but instead is
cut straight diagonally. Look at the far side (right side), you can see it is rounded.
Furthermore, if you look closely, you will notice several vertices lined up along the chamfered area. Why do these "artifacts" appear? Before the chamfering, it was just
a straight corner with a single vertex.
I have examined all vertices, edges, polygons of this table, but there are no irregularities.
I would greatly appreciate any input. Even hints or suspicions would be greatly helpful.
There is something weird with your geometry (obviously). Try to select all verteces and weld with a small amount, then do the chamfer again. I bet you have some intersecting geometry. An easy fix is to delete all the polygons that are extruded, select the edges of the hole, press cap, then select that poly and extrude again, then select the bottomn edge and chamfer.
