a problem with render setup
minaabadi
hi guys
I've defined my render setup in common tab,as a single frame . but apparently it renders all 100 frames like animation... as below:
the settings in common tab is as below:
what is wrong? please help me.
You are using progressive rendering, which renders in passes to refine a single image. A high quality image make take thousands of passes to get to the final level of quality. What you are seeing is completely normal and you are not rendering hundreds of individual frames.
thank you so much, I found the answer :)
