charlie inolas Posted May 21, 2016 Share Posted May 21, 2016 (edited) Hi, Is this possible to make vrayLight plane invisible, but only for vray sun so it could let through the light beams ? I want to put one plane behind the window but I want it to remain burnt white so it could let through sun beams at the same time. thanks! Edited May 21, 2016 by charlieinolas Link to comment Share on other sites More sharing options...
Casey Hawley Posted June 2, 2016 Share Posted June 2, 2016 As far as I know light planes don't block light, but I've never tested it. Do you lose your sun beam with a normal light plane behind the window? Try making it a portal light. There are tons of tutorials out there about how to set up a proper vray sun/sky with portal lights solution. Good luck! Link to comment Share on other sites More sharing options...
