jonasmotiejunas Posted May 21, 2016 Share Posted May 21, 2016 Hello. Is it possible to create color variation per item without the use of forest color? I need to manually scatter a curtain object to hide the building interior, but without using the forest pack itself, the forest color map doesnt seem to work. Any tips? Thank you. Link to comment Share on other sites More sharing options...
Andres Saarnak Posted May 21, 2016 Share Posted May 21, 2016 One way is to collapse all curtains and use MaterialByElement modifier and MultiTexture. Or if you copy-paste your curtains anyway, use ForestPack in Custom Edit mode to copy-paste and forest color works. Link to comment Share on other sites More sharing options...
jonasmotiejunas Posted May 21, 2016 Author Share Posted May 21, 2016 thanks. will try Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted May 23, 2016 Share Posted May 23, 2016 The forest map only works on objects scattered with forest pack. However if you use railclone you can create a multisub material and set the pieces generated by railclone to have a random material ID. Link to comment Share on other sites More sharing options...
Andres Saarnak Posted May 23, 2016 Share Posted May 23, 2016 When you use forest to copy-paste it´s important to select all items in the forest pack object and click Re-Seed under Tree Editor tab. Otherwise, it won´t give random matID to copied items. Link to comment Share on other sites More sharing options...
