Camera Match Drone Photography
Dave Buckley
So more and more these days I'm camera matching drone footage/stills.
Normally they're quite high, but I've got one at the minute that's quite low down.
To be honest I normally eyeball the match but this requires accurate date.
The only thing I'm struggling with is replicating the drones camera settings into 3ds max.
I've inserted what I think, but the camera seems way off so I think I've missed something.
I've attached the drone data, if anyone knows what I should be putting in Max that would awesome.
Have you taken into account sensor size? I find it a lot easier to set the actual sensor size and focal length than working out crop factors.
+1
And I eyeball it anyway, I get poor results most of the time with max camera matching tools. Large building and drone panoramas are specially difficult for me when all straight lines are curved and weird. I have used PS to correct lens and distort both photo and rendering to match them...only minor corrections, though, it can get bad pretty quick.
Yeh, this is why I asked, I don't actually know the true focal length, I only have a 35mm equivalent.
The closest I'm getting is by using a film gate of 36 and focal length of 20. That does get me pretty close, I'm starting to think my context model is out though. It's the only thing I have to camera match to though, so I think I'm gonna stick with where I'm at and tweak in post from there.
I've always found the "35mm equivalent" focal lengths to be approximations. On this thread, someone says the focal length of a Phantom 3 (which your provided specs seem to match) is 3.61mm with a sensor size of 6.16mm x 4.62mm.
With a Max Physical Camera, try a sensor width of 6.16mm and a focal length of 3.61mm. That gives a horizontal FOV of 80.936 degrees if you're using the a Max Free/Targeted Camera.
