sergeicokaar Posted May 30, 2016 Share Posted May 30, 2016 Hi guys I really need help and fast. So here's the problems, when i put anything into environment slot (be is hdri or VraySky) i get real harsh shadows but not from the sky but from down bellow, same with Vray light(plane) out side the window, but with the case on plane its either no shadows or same weird upward shadows(if set as light portal) as with environment slot. I checked everything the file's up is up, and its not the window or glass problem. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted May 30, 2016 Share Posted May 30, 2016 Check the whole scene if you have hidden lights, also put a plane or something under your buildings. always this will help you to have better light bounce too. Also drag the environment shader to the material editor and check the orientation or coordinates of it, maybe they got flip or something. Link to comment Share on other sites More sharing options...
sergeicokaar Posted May 31, 2016 Author Share Posted May 31, 2016 Sooo, i checked everything. No hidden lights, all vray (mats and lights), no hidden\stray objects, BUT those shadows are not shadows at all htay are reflection and specular Vray specular pass(same in reflection pass but slightly more blurry) VrayLighting (normal shadows, shadows are from LightDome With HDRI) Link to comment Share on other sites More sharing options...
