maximilianwarwitz Posted May 31, 2016 Share Posted May 31, 2016 Hey guys I´m trying to build a conscruction where I connect two machines with a cable. But now I want the cable to follow the rules of gravity. The cable should fall on the ground in the middle of the cable but stays connected with the machines. I haven´t done much with MassFX tbh. First I thought it might be easier to move the cable manually but I guess it won´t look realistic enough..The cable is 70cm above the ground. I hope it´s not a big issue and that you can help me very easily Thx for your help! Maximilian Link to comment Share on other sites More sharing options...
Chris MacDonald Posted May 31, 2016 Share Posted May 31, 2016 Sounds like a bit overkill unless you're animating it? Maybe try this instead? http://www.scriptspot.com/3ds-max/scripts/catenary-curve-generator Link to comment Share on other sites More sharing options...
maximilianwarwitz Posted May 31, 2016 Author Share Posted May 31, 2016 Thanks a lot I´ll try that later today! Link to comment Share on other sites More sharing options...
