johnjohnson3 Posted June 3, 2016 Share Posted June 3, 2016 Hi, I have a small problem with using Loft in 3Ds Max, as you can see in the image the shap does not follow the path. What I have to do to get it correctly? Thank you Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted June 8, 2016 Share Posted June 8, 2016 Look here https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMax/files/GUID-4CCA4890-83E8-41C6-9FFB-0A3959194CCA-htm.html See the "Note:" regarding location. I'll further add, if you don't need any of the fancy features of the Loft compound object, try a sweep. It's what I use for all my cornices etc. Link to comment Share on other sites More sharing options...
akshayarora Posted June 8, 2016 Share Posted June 8, 2016 Keep the CTRL button pressed , while picking the path . Link to comment Share on other sites More sharing options...
