kenchen Posted June 6, 2016 Share Posted June 6, 2016 Hi Everyone First time posting here. I'vegot a problem with one of my renders. As you can see from the image my GI map has all these dark black spots everywhere. This is a camera fly through of a bedroom/bathroom. Nothing too fancy. I've followed the basic set-up for an animation like this. I pre-baked the GI using these settings. 1st bounce Irradiance map Pre-set min rate -4 max rate -1 subD 250 Interp samples 60 checked use camera path. mode: incremental add to current map 2nd bounce light cache. sub D 3200 checked show cal phase world scale use camera path mode single frame image sampler adaptive min 1 max 8 threshold 0.005 the whole animation is 365 frames. What really baffled me is i have other animations that's similar but different room with almost identical settings and they all render out fine. I did some test where I just baked out the first 10 frames of this animation and did a test render. Everything looked ok no black spots. When I go and bake out all 365 frames the black spots appear. Im using Maya 2014 vray 3.3 Some help would be greatly appreciated. If i left out any information please let me know Thanks, Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted June 7, 2016 Share Posted June 7, 2016 Definitely you did something wrong here, hard to tell where, but from your settings I thing you are changing too many parameters that you are not sure how they works. Just reset all the values of VRay, use a mediums settings for Irr, leave LC as default and you should get a better image. Please referee the manual, and the basic tutorial that come with VRay, they'll explain with good detail how each parameter works. Link to comment Share on other sites More sharing options...
