mikekime Posted June 12, 2016 Share Posted June 12, 2016 I have been working on more or less the same scene for a bit now. With some basic Progressive settings I would just get a quick 1 minute render out and it would dump all the element and primary frames. All in reasonable time. Now, out of the blue, its taking a long time after it reaches 100%. In 1 minute it reaches 100% and says EST 1:05. Then the actual time keeps counting up. It can get up to like 5 minutes at max CPU before it actually (and immediately) kicks out the output files and actually ends. I tried setting it to 5minute and it seemed to be the exact same only the green bar took to the 5 minutes to complete instead of 1. What caused this change? How can i get to a complete progressive render earlier (like it was) . Like 1 minute total. Or 2 minutes. I don't understand why it just goes beyond the 1min minimum now. Thanks Link to comment Share on other sites More sharing options...
phanigurram Posted August 19, 2016 Share Posted August 19, 2016 Save after rendering is better option otherwise it takes more than 10 mins. Don't know actual problem .are you using VRAY 3.2 . Link to comment Share on other sites More sharing options...
phanigurram Posted August 19, 2016 Share Posted August 19, 2016 Sorry bad idea even if you try like that you will be delayed for saving the images. Are you using VRAY 3.2 Link to comment Share on other sites More sharing options...
phanigurram Posted August 19, 2016 Share Posted August 19, 2016 Did you find any solution. Link to comment Share on other sites More sharing options...
