Vray Noise Issue 3Ds Max 2015 with Vray 3.30
rehankhalil2
Hi, to all Good Day, I m using 3ds max 2015 with vray 3.30, but in 3d views too much Nosing in image i m , High value Antialiasing. Also image quality color not good as like i m using 3d max 2014 with vray 2..40.0.
Using Anti aliasing . Adaptive , High Value
Using : Irradiance map. & Light Cache. 30/30 Low.
Please guide me. Rehan
Edited by rehankhalil2
First, there is a free update for paid customers of V Ray, latest version is 3.4.02
This one has a new feature called denoiser. It will help you a lot.
Second, check your probabilistic lights values, always set it to the same amount of lights in your scene. Or just turn it off, but it help to render a little faster.
30/30 for IRR is very low. set to default medium 70/20 ot 70/50 and test again.
I've been using Mental Ray for 9+ years, Vray for a few months and I will never go back, it's FAR FAR superior given the results you can achieve.. although the noise problem is getting to me.. I just don't know the rendering engine well enough yet. This tutorial unfortunately contains everything i've already tried and i'm still struggling.
Guest dialog
Couple of quick fixes for noise, but the one i see for most people just starting out is the "probabilistic lights" checkbox is enabled. Try disabling this. If you still get noise then it is more than likely your render settings. Materials that are VRaLightMtl will also add considerable amount of noise to your scene.
As a rule of thumb, always set the number for probabilistic lights to the same number of lights in your scene. Default is 16, if you have less than that, it won't make any difference. When you have higher number of lights, 20, 50, 100 or more, then adjust probabilistic lights accordingly, this will really increase your rendering speed.
VRay light materials are not optimized like Corona light Materials, so they produce extra noise when used with direct light option. If you leave that check box off, it should not give you noise, only increase the amount of ambient lighting.
Guest dialog
VRay light materials are not optimised like Corona light Materials, so they produce extra noise when used with direct light option. If you leave that check box off, it should not give you noise, only increase the amount of ambient lighting.
See the attached... as you can see with the checkbox unchecked, it gives you considerable amount of noise vs converting the source to a mesh light.
Well I understand that the first post was about IRR and LC, in that case, what I said still apply.
If you are rendering Brute force, you'll get noise. Light material is not considered as light per say, so if you check the direct light, then it will sample as a light. It may render even faster.
sigh... V-Ray and all it twinks :/
Prefer Corona over Vray for archviz. Doesnt give you as many elements for post but the 3D lighting is much more appeasing. The matte pass is still a bit difficult to get working the way I expect but still prefer it so far.
I also like the fact Corona you dont adjust any subdivs or render settings (unless you turn on denoiser, its a good idea). Vray is hot on its heels in this regard, but for simplicity - Corona.
Edited by redvella
