rehankhalil2 Posted June 14, 2016 Share Posted June 14, 2016 (edited) Hi, to all Good Day, I m using 3ds max 2015 with vray 3.30, but in 3d views too much Nosing in image i m , High value Antialiasing. Also image quality color not good as like i m using 3d max 2014 with vray 2..40.0. Using Anti aliasing . Adaptive , High Value Using : Irradiance map. & Light Cache. 30/30 Low. Please guide me. Rehan Edited June 14, 2016 by rehankhalil2 Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted June 14, 2016 Share Posted June 14, 2016 First, there is a free update for paid customers of V Ray, latest version is 3.4.02 This one has a new feature called denoiser. It will help you a lot. Second, check your probabilistic lights values, always set it to the same amount of lights in your scene. Or just turn it off, but it help to render a little faster. 30/30 for IRR is very low. set to default medium 70/20 ot 70/50 and test again. Link to comment Share on other sites More sharing options...
rehankhalil2 Posted June 15, 2016 Author Share Posted June 15, 2016 Thank You sir, 1- can you tell me where to download Vray Denoiser Plugin. 2- Noise reduce, but still not good. when i used medium 70/50 IRR. Please reply me. Thank you again sir. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted June 15, 2016 Share Posted June 15, 2016 Denoiser is a new pass that come with V Ray 3.4 it is a free upgrade to owners of 3.3. If you go to default values on VRay, eather 3.3 or 3.4 with antialising 1-24 and IRR medium and LC to 1500 or so, you should get a more cleaner image. Link to comment Share on other sites More sharing options...
rehankhalil2 Posted June 16, 2016 Author Share Posted June 16, 2016 Thank You Sir, Where to download Denoiser, i have Vray 3.30 & Vray 3.40 using 3ds Max 2015. Good Bye. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted June 16, 2016 Share Posted June 16, 2016 it is in passes. refer to the manual for more details. Link to comment Share on other sites More sharing options...
rehankhalil2 Posted June 17, 2016 Author Share Posted June 17, 2016 Thank You. now image is Good without noise with short time. Special Thank Sir,. Link to comment Share on other sites More sharing options...
rehankhalil2 Posted June 17, 2016 Author Share Posted June 17, 2016 Please help me. Backburner not install why ? i m using 3ds Max 2014 & also same problem 3ds Max 2015. Thank You. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted June 17, 2016 Share Posted June 17, 2016 That message looks really Iffy.... Link to comment Share on other sites More sharing options...
Guest dialog Posted June 17, 2016 Share Posted June 17, 2016 Uncheck probablistic lighting... might fix the issue. IES lights can sometimes be noisy as well Link to comment Share on other sites More sharing options...
jasminepeterson Posted June 20, 2016 Share Posted June 20, 2016 I've been using Mental Ray for 9+ years, Vray for a few months and I will never go back, it's FAR FAR superior given the results you can achieve.. although the noise problem is getting to me.. I just don't know the rendering engine well enough yet. This tutorial unfortunately contains everything i've already tried and i'm still struggling. Link to comment Share on other sites More sharing options...
Guest dialog Posted June 20, 2016 Share Posted June 20, 2016 I've been using Mental Ray for 9+ years, Vray for a few months and I will never go back, it's FAR FAR superior given the results you can achieve.. although the noise problem is getting to me.. I just don't know the rendering engine well enough yet. This tutorial unfortunately contains everything i've already tried and i'm still struggling. Couple of quick fixes for noise, but the one i see for most people just starting out is the "probabilistic lights" checkbox is enabled. Try disabling this. If you still get noise then it is more than likely your render settings. Materials that are VRaLightMtl will also add considerable amount of noise to your scene. Link to comment Share on other sites More sharing options...
inpow watir Posted June 23, 2016 Share Posted June 23, 2016 Thank You. now image is Good without noise with short time. Special Thank Sir,. I guessed that is why they introduced a new de-noiser pass along with the new adaptive algorithm Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted June 23, 2016 Share Posted June 23, 2016 Couple of quick fixes for noise, but the one i see for most people just starting out is the "probabilistic lights" checkbox is enabled. Try disabling this. If you still get noise then it is more than likely your render settings. Materials that are VRaLightMtl will also add considerable amount of noise to your scene. As a rule of thumb, always set the number for probabilistic lights to the same number of lights in your scene. Default is 16, if you have less than that, it won't make any difference. When you have higher number of lights, 20, 50, 100 or more, then adjust probabilistic lights accordingly, this will really increase your rendering speed. VRay light materials are not optimized like Corona light Materials, so they produce extra noise when used with direct light option. If you leave that check box off, it should not give you noise, only increase the amount of ambient lighting. Link to comment Share on other sites More sharing options...
Guest dialog Posted June 23, 2016 Share Posted June 23, 2016 As a rule of thumb, always set the number for probabilistic lights to the same number of lights in your scene. Default is 16, if you have less than that, it won't make any difference. When you have higher number of lights, 20, 50, 100 or more, then adjust probabilistic lights accordingly, this will really increase your rendering speed. VRay light materials are not optimised like Corona light Materials, so they produce extra noise when used with direct light option. If you leave that check box off, it should not give you noise, only increase the amount of ambient lighting. See the attached... as you can see with the checkbox unchecked, it gives you considerable amount of noise vs converting the source to a mesh light. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted June 23, 2016 Share Posted June 23, 2016 Well I understand that the first post was about IRR and LC, in that case, what I said still apply. If you are rendering Brute force, you'll get noise. Light material is not considered as light per say, so if you check the direct light, then it will sample as a light. It may render even faster. sigh... V-Ray and all it twinks :/ Link to comment Share on other sites More sharing options...
James Vella Posted June 23, 2016 Share Posted June 23, 2016 Ive got some pretty solid vray render settings for most situations, noise free you can see here (not sure how 3.4 affects this since im using corona now); http://jamesvella.blogspot.com.au/p/rayfire-multitexture-render-settings.html Link to comment Share on other sites More sharing options...
Guest dialog Posted June 24, 2016 Share Posted June 24, 2016 Ive got some pretty solid vray render settings for most situations, noise free you can see here (not sure how 3.4 affects this since im using corona now); http://jamesvella.blogspot.com.au/p/rayfire-multitexture-render-settings.html How do you like Corona vs VRay? Link to comment Share on other sites More sharing options...
James Vella Posted June 26, 2016 Share Posted June 26, 2016 (edited) Prefer Corona over Vray for archviz. Doesnt give you as many elements for post but the 3D lighting is much more appeasing. The matte pass is still a bit difficult to get working the way I expect but still prefer it so far. I also like the fact Corona you dont adjust any subdivs or render settings (unless you turn on denoiser, its a good idea). Vray is hot on its heels in this regard, but for simplicity - Corona. Edited June 26, 2016 by redvella Link to comment Share on other sites More sharing options...
Nic H Posted June 27, 2016 Share Posted June 27, 2016 you can use vray like that with progressive. or with bucket and just adjust the noise threshold Link to comment Share on other sites More sharing options...
