Sketchrender Posted June 24, 2016 Share Posted June 24, 2016 Hi I am sorry if this has been covered, but I did look and could not find the topic. I want to render out a number of views, and the usual 200-300 passes, and then also export render elements also so I can do post work in photoshop. In Vray I would go to Frame buffer and set it up there. So whats the equivalent in Corona. Thank you philip Link to comment Share on other sites More sharing options...
jensandersen Posted June 24, 2016 Share Posted June 24, 2016 Check the Corona forum: https://corona-renderer.com/forum/index.php/topic,10696.0.html Also, you should upgrade to 1.4 and try the new denoiser feature. You'll be amazed of how few passes is needed now Link to comment Share on other sites More sharing options...
