darkoivic Posted July 28, 2016 Share Posted July 28, 2016 Hi, I have a little problem importing curved objects, modeled in CAD. I think there has to be a smoothing option that solves this situation. I have created an arc solid in CAD and it looks smooth enough for me, but when I import it in max it looks faceted. I have tried to play with "Curve Steps" in Import Options but apparently it is only affecting splines and not objects. Please help! Link to comment Share on other sites More sharing options...
Sketchrender Posted July 28, 2016 Share Posted July 28, 2016 There is an option on the import port box to define the amount of sections you want in the curve, curve steps I think. Check it out. Or just remodel it, sometimes that is much quicker. Link to comment Share on other sites More sharing options...
darkoivic Posted July 28, 2016 Author Share Posted July 28, 2016 There is an option on the import port box to define the amount of sections you want in the curve, curve steps I think. Check it out. Yes I have tried it, but it seems that it works only with splines and polylines, not solids. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted July 28, 2016 Share Posted July 28, 2016 you need to adjust in AutoCAD first. FACETDEV facetratio: 0 aecfacetdev: 0.001 facetres: 0.01 hope this help Link to comment Share on other sites More sharing options...
darkoivic Posted July 29, 2016 Author Share Posted July 29, 2016 facetratio: 0 aecfacetdev: 0.001 facetres: 0.01 thanks a lot! Link to comment Share on other sites More sharing options...
Vince Paske Posted August 18, 2016 Share Posted August 18, 2016 You are looking for Maximum surface deviation in the import dialogue. Set it to a very low, or zero value to get smooth solids from AutoCad, Link to comment Share on other sites More sharing options...
