Distributed Rendering Issue
akshayarora
Fixed it.
Uninstall VRay then reboot.
Uninstall Max then reboot.
Install Max then reboot.
Install VRay then reboot.
DO NOT INSTALL THE SPAWNER. Manually start DR.
Try the steps above.
Hello Larissa ,
Thanks for the reply ,
Do I need to do all these steps in Main pc or slave pc's. ?
There are many threads here regarding this. I know I've helped on a couple. It's been awhile since I've had to set up DR, so again I refer you to the other threads here. Post back if still having trouble.
Hello Casey ,
I studied most of the forums before posting , Most people skipped the step of this part . Can you post the link if you remember that post ?
One important step that was always left out of the instructions is to set the Spawner service to run under administrative user credentials. Get properties on the service, then change 'Logon' to admin user/pass, instead of Local. BUT... this was back with VRay 2.4 and earlier. Worth a look tho, me thinks.
