trhoads Posted December 1, 2004 Share Posted December 1, 2004 In our new Politically Correct age, now even Autodesk apologizes for errors. I laughed way too hard at this one, thought I would share it. Link to comment Share on other sites More sharing options...
vizwhiz Posted December 1, 2004 Share Posted December 1, 2004 hi There TR what were you doing when This happened? i went Thru This just the last 4 weeks and it went away ONLY when a 3 gb switch was installed for the rendering process dont worry Cdilla.exe reports a LOT of YOUR INFO to Autodesk or somewhere else every TIME your start VIZ (its a spyware according to some anit-spyware softwares) ** Randy Link to comment Share on other sites More sharing options...
trhoads Posted December 1, 2004 Author Share Posted December 1, 2004 This occured in AuoCAD 2004. It happens when you try to open a file. Nothing fancy, just trying to open a file. It is not on my machine, and that is a good thing. It is on the oldest in the machine in the office. I think there are ghosts in that computer. I just found it amusing. Link to comment Share on other sites More sharing options...
Tim Nelson Posted December 2, 2004 Share Posted December 2, 2004 Hehe, get a load of this one! An error message over the error message! Viz just started crashing every time I open it now (even just opening the app. only) Funny....but not! Link to comment Share on other sites More sharing options...
Ernest Burden III Posted December 3, 2004 Share Posted December 3, 2004 Autodesk has a lot to appologise for. Link to comment Share on other sites More sharing options...
trhoads Posted December 3, 2004 Author Share Posted December 3, 2004 Timmatron said: Hehe, get a load of this one! An error message over the error message! Now that one is funny. Have not seen that one yet. I hope I don't. Hope you get it working. Link to comment Share on other sites More sharing options...
Fran Posted December 3, 2004 Share Posted December 3, 2004 Tim - try opening Viz in software display mode. Link to comment Share on other sites More sharing options...
Tim Nelson Posted December 3, 2004 Share Posted December 3, 2004 Can you give me a hint on how to do that? Thanks. Link to comment Share on other sites More sharing options...
Fran Posted December 3, 2004 Share Posted December 3, 2004 Timmatron said: Can you give me a hint on how to do that? Thanks. Hi Tim, If you're using Viz 2005, go to the Start menu->Programs->Autodesk->Autodesk VIZ 2005->Change Graphics Mode. When (if) VIZ starts, you are offered graphics mode options. For VIZ 4, create a shortcut to VIZ and edit the Target to something like this: "C:\Program Files\Autodesk VIZ 4\3dsviz.exe" -h The "-h" switch is what does the trick. Just add it to the Target path for the shortcut properties. It has to be outside of the double quotes. Link to comment Share on other sites More sharing options...
Tim Nelson Posted December 3, 2004 Share Posted December 3, 2004 Thanks Fran. I have 2005 and what you told me to do worked & I switched to software mode, but unfortnately as soon as Viz finished loading up it gave the the error message & closed. A big WHATEVER to that! I think I'll just have to re-install. Link to comment Share on other sites More sharing options...
