Jon Berntsen Posted August 11, 2016 Share Posted August 11, 2016 (edited) I see them more often than before: High detailed and very nice looking windows in interiors. It almost seems like common knowledge, only that I missed out on everything. How do people make them? Sure they're not modelled from CAD software, neighter are they made with Max windows. BIM models? If BIM, I'm sure a lot of renders are using wrong types of windows. Low cost renders + high detailed correct windows does not fit together. Any advice? Thanks. Edited August 11, 2016 by chroma Link to comment Share on other sites More sharing options...
Andres Saarnak Posted August 11, 2016 Share Posted August 11, 2016 Download CAD profile from windows manufacturer and sweep it around window lines. I think there´s tutorial on this on The Boundary website(modeling and materials) and on Talcik-Demovicova Vimeo (if I remember correctly, don´t have time to check right now). Link to comment Share on other sites More sharing options...
Jon Berntsen Posted August 11, 2016 Author Share Posted August 11, 2016 Thanks, but there has to be a lot more to it. If one's gonna use two days to remodel windows on each project, the competition will be kind of strong pricewise... Link to comment Share on other sites More sharing options...
Scott Schroeder Posted August 11, 2016 Share Posted August 11, 2016 There are only a few sweeps you need to make and let a tool RailClone take care of the rest. Windows are all generally the same, it's the grid spacing that changes. http://www.itoosoft.com/tutorials/tutorial_parameterise_windows.php?back=page%3D1 Gone are the days of doing all of this by hand. Link to comment Share on other sites More sharing options...
Andres Saarnak Posted August 11, 2016 Share Posted August 11, 2016 Why two days? It can´t get much simpler than this- you have a rectangle and sweep it with windows profile. Most time consuming might be finding CAD profiles and you do it once. Link to comment Share on other sites More sharing options...
Jon Berntsen Posted August 11, 2016 Author Share Posted August 11, 2016 There are only a few sweeps you need to make and let a tool RailClone take care of the rest. Windows are all generally the same, it's the grid spacing that changes. http://www.itoosoft.com/tutorials/tutorial_parameterise_windows.php?back=page%3D1 Gone are the days of doing all of this by hand. Ahhhh RailClone. Yes, we own RailClone, and I will take an in-depth look! Seems like the answer. Thank you! Link to comment Share on other sites More sharing options...
Jon Berntsen Posted August 11, 2016 Author Share Posted August 11, 2016 (edited) Why two days? It can´t get much simpler than this- you have a rectangle and sweep it with windows profile. Most time consuming might be finding CAD profiles and you do it once. What about hinges, rubber band and aluminium edges? Also small spaces between 45° angled pieces add to photorealism. How can this be done easily and quick with using a profile? However, doing this once or twice per project and use rail clone for parametrics, sounds promising. I will definitely try that approach. Edited August 11, 2016 by chroma Link to comment Share on other sites More sharing options...
Chris MacDonald Posted August 11, 2016 Share Posted August 11, 2016 What about hinges, rubber band and aluminium edges? Also small spaces between 45° angled pieces add to photorealism. How can this be done easily and quick with using a profile?. That can all be done using a sweep and simply applying material ID's to the relevant sections. Link to comment Share on other sites More sharing options...
RyderSK Posted August 11, 2016 Share Posted August 11, 2016 Hah, it's definitely not a single sweep :- ). But neither is it two days. Some of the most detailed windows (made from CAD data from manufacturers like Schueco,etc.. ) can take few hours to make a set (because usually you need few dimensions, separations, windows/doors,etc..). But then you get a huge reuse out of them. It's rare that most jobs will specify windows, and there are only so many generic aluminium windows that are used for common real estate. At the moment we're using the same windows for Zaha Hadid skyscrapper we made for townhouse before. Here is a window we modelled last (this is photo, no render yet), again from Schuco. Hardly a single sweep, this one took some time... the competition will be kind of strong pricewise... Not sure I understood this right but our stance is that these kind of details come through and warrant your higher price in eyes of clients. They definitely notice it. Link to comment Share on other sites More sharing options...
Virgil Johnson Posted August 11, 2016 Share Posted August 11, 2016 I tend to do mine in Revit. Since I have to produce construction documents...Revit is generally my modeling program of choice. For me visualization is not an end product but a design process (product). Link to comment Share on other sites More sharing options...
Jon Berntsen Posted August 11, 2016 Author Share Posted August 11, 2016 Hah, it's definitely not a single sweep :- ). But neither is it two days. Some of the most detailed windows (made from CAD data from manufacturers like Schueco,etc.. ) can take few hours to make a set (because usually you need few dimensions, separations, windows/doors,etc..). But then you get a huge reuse out of them. It's rare that most jobs will specify windows, and there are only so many generic aluminium windows that are used for common real estate. At the moment we're using the same windows for Zaha Hadid skyscrapper we made for townhouse before. Here is a window we modelled last (this is photo, no render yet), again from Schuco. Hardly a single sweep, this one took some time... Not sure I understood this right but our stance is that these kind of details come through and warrant your higher price in eyes of clients. They definitely notice it. So you are making one version for each dimension, or are you modeling elements that you make parametric with rail clone? Link to comment Share on other sites More sharing options...
numerobis Posted August 11, 2016 Share Posted August 11, 2016 Here is a window we modelled last (this is photo, no render yet), again from Schuco. Are you sure that this is a photo? I would say rendering. Link to comment Share on other sites More sharing options...
RyderSK Posted August 11, 2016 Share Posted August 11, 2016 So you are making one version for each dimension, or are you modeling elements that you make parametric with rail clone? I don't use RailClone yet, we suck that much. Plan to incorporating it, among backlog of thousands other things. No time. Modifying one version to other with simple edit poly modifier takes just moment. Are you sure that this is a photo? I would say rendering. Very tired from long post-production, so I wouldn't catch your joke, but in case you mean it :- ) it's a photo from Villa Chameleon in Spain, not a rendering. Architectural photography is always so clean and perfect, no one tries to use iPhone like lens with chroma abberation, vignetting, grime in corners, and other "photorealistic" elements. Link to comment Share on other sites More sharing options...
Nic H Posted August 12, 2016 Share Posted August 12, 2016 id like to purchase some high quality windows Link to comment Share on other sites More sharing options...
Jon Berntsen Posted August 12, 2016 Author Share Posted August 12, 2016 (edited) My best solution so far: http://www.bimobject.com. Then import to max, and do correct shading and additional detailing -> save out to own library. And as jurij said, it's just an edit poly modifier and you're good to go for any size change. The problem is that it do take some time. I think we need to give customers two options. Eighter 1) detailed doors/windows, or 2) just plain and simple from ArchiCad. I believe it would make a difference about $150-$300 per project. Do you think customers are willing to pay for this Juraj? Edited August 12, 2016 by chroma Link to comment Share on other sites More sharing options...
Ernest Burden III Posted August 12, 2016 Share Posted August 12, 2016 My best solution so far: http://www.bimobject.com... Thank you for that! Link to comment Share on other sites More sharing options...
Jon Berntsen Posted August 12, 2016 Author Share Posted August 12, 2016 thank you for that! np! Link to comment Share on other sites More sharing options...
RyderSK Posted August 15, 2016 Share Posted August 15, 2016 Never seen that either, will give it try too. Wonder what the quality is. Recently I started to use a lot of CAD files that I previously shied away because I simply put 'edge map' (different name in every engine, basically render-time chamfer ) in material and get the illusion of nicely detailed high-poly object, without the need to remodel crap. I am still not biggest friend with Revit, but this lessens the conversion to clean-up, instead of remodelling everything. I believe it would make a difference about $150-$300 per project. Do you think customers are willing to pay for this Juraj? Well I don't include "detailed modelling" in invoice :- ) It's just part of the visual quality I will sell. Doesn't necessarily bring more profit though, you sell for higher-price, and then work on it longer. Which for me in the end, is still the better deal. There are clients willing to pay for every project tier. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted August 15, 2016 Share Posted August 15, 2016 A couple of years ago i made a rig for a window model that kind of worked like this: Sweep/edit poly/whatever to create a window using whatever profiles you want. Then in each corner you place a dummy object and link the verteces of each corner of the window to the corresponding dummy. You could even i guess create four more dummy objects and link the corner dummies to those to create easily manipulated height/width dummies to negate having to select two dummy objects every time you adjust either width or height. Anyways then it was just a matter of using the snap to function and snap the dummies to the corners of the holes in the wall, and the window would follow/deform to whatever size of hole you had in your wall, while keeping the dimensions of the sweep/geometry of your window. Then clone the window with the dummy-rig and repeat the process for a differently sized window. Takes about half an hour or something to set up, but it may be worthwhile checking out. Link to comment Share on other sites More sharing options...
Virgil Johnson Posted August 15, 2016 Share Posted August 15, 2016 Revit is pretty useful when you are going to use the drawings for actual building. - remembering that some of the elements drawn are sent directly to a CNC machine. Kind of a case of what you see is really what you get. Drill down and you will find Revit is very good at parametrics. A lot more discipline than something like Max but if you are doing architecture... Link to comment Share on other sites More sharing options...
numerobis Posted August 15, 2016 Share Posted August 15, 2016 Very tired from long post-production, so I wouldn't catch your joke, but in case you mean it :- ) it's a photo from Villa Chameleon in Spain, not a rendering. No joke ;-) I really thought it is a rendering. Link to comment Share on other sites More sharing options...
heni30 Posted August 15, 2016 Share Posted August 15, 2016 What qualities made you think it was a rendering? I think we're overdoing it when reality isn't real enough. Link to comment Share on other sites More sharing options...
RyderSK Posted August 15, 2016 Share Posted August 15, 2016 I think we're overdoing it when reality isn't real enough. I think we are way behind that point for long time now :- ) I see very often people criticizing real-life phenomenon in archviz images because they never paid attention to them ( like inner reflections, and mirror/DOF relationship ), and over-doing everything else to extreme ( super brushed specular on modern wall paint ? ) and scratches and scuffs for the sake of realism. Link to comment Share on other sites More sharing options...
Nic H Posted August 15, 2016 Share Posted August 15, 2016 arch vis dudes and architect men do the weirdest things imo that BIM site looks useful for wiondows but is all dirty revit files Link to comment Share on other sites More sharing options...
