keloy Posted August 12, 2016 Share Posted August 12, 2016 [my company upgraded our 3ds max. from max2013 to max 2017 vray 3.4 render setting is different from max 2013. if you can see the corners of walls and ceiling there are black line and i think spot of lights. i hope you can help me.. thanks in advance ATTACH=CONFIG]54602[/ATTACH] Link to comment Share on other sites More sharing options...
keloy Posted August 12, 2016 Author Share Posted August 12, 2016 ???? Link to comment Share on other sites More sharing options...
dhawalpahadiawala Posted August 12, 2016 Share Posted August 12, 2016 Prima facie it seems that the black lines we see are due to Ambient Occlusion. Increase the radius of AO to something like 150 mm or 6 inches. Render setup --> GI --> click on basic to open AO options and then increase the radius. Link to comment Share on other sites More sharing options...
John Dollus Posted August 12, 2016 Share Posted August 12, 2016 Are you using IR/LC for your GI? could be ao is on in the GI tab and you need to turn on the retracing for light cache. switch to brute force and see if you still get the problem. Link to comment Share on other sites More sharing options...
