afkariaziz1 Posted August 14, 2016 Share Posted August 14, 2016 Hello. I am trying to render water eg I create a plane and attach a material with bump map with noise and then when I render. It appears flat and looks like glass. What is happening??? Thanks Link to comment Share on other sites More sharing options...
pablovergara Posted August 14, 2016 Share Posted August 14, 2016 Check the mapping of your material onto the plane. Create a checkerboard material and apply it to the plane and see if it looks like it should, dimensions-wise. Then re apply the water material and render. See how it goes Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
afkariaziz1 Posted August 14, 2016 Author Share Posted August 14, 2016 (edited) it dosent work. thanks Edited August 14, 2016 by afkariaziz1 Link to comment Share on other sites More sharing options...
pablovergara Posted August 14, 2016 Share Posted August 14, 2016 Try some water materials from vraymaterials.de Maybe there's something wrong with your material Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
pablovergara Posted August 14, 2016 Share Posted August 14, 2016 Is the scale of the project correct? It could be that too Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Nic H Posted August 15, 2016 Share Posted August 15, 2016 have you tried scattering bumps on the water using forest pro Link to comment Share on other sites More sharing options...
landrvr1 Posted August 15, 2016 Share Posted August 15, 2016 Let's try this: Water Material: Set your bump map to 5.0 Add a SMOKE map to the bump slot. Smoke Parameters: size 50 phase 0 #iterations = 5 Exponent = 1.5 Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted August 15, 2016 Share Posted August 15, 2016 nicnic said: have you tried scattering bumps on the water using forest pro say what????? Link to comment Share on other sites More sharing options...
afkariaziz1 Posted August 15, 2016 Author Share Posted August 15, 2016 It doesn't work either. The scale is correct I think eg the walls are in meters like 150mm wide etc Link to comment Share on other sites More sharing options...
Nic H Posted August 15, 2016 Share Posted August 15, 2016 ok what about modelling the water or using realflow to fill the pool then build a fan to blow air over it - that will give you relistic vray Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted August 15, 2016 Share Posted August 15, 2016 The problem is simple really, you need to find the right scale, you could use displacement or bump, but if your scale is not correct, then it won't render. How did you modeled that water?? REVIT? Sketchup or inside Max? Just apply a reset xform, the collapse, add some subdivisions to that plane, put the noise map in the bump channel and be sure that the texture visible in the viewport and adjust until you can see it. Then render and check the scale. for stronger effect you may want to increase the contrast between white and black. Change the Noise threshold to 0.7 to high and 0.4 to low You could always paint some B/W map in photoshop and use it as displacement map too. but again you need to be sue that you have a correct UVWmap and a correct scale. You could also put a plane with lots of subdivisions and apply a ripple modifier, with noise modifier. Link to comment Share on other sites More sharing options...
afkariaziz1 Posted August 15, 2016 Author Share Posted August 15, 2016 it is still not working. i tried the uv map and your advice per se. tried the material too from vray material.de [/img] Link to comment Share on other sites More sharing options...
Chris MacDonald Posted August 15, 2016 Share Posted August 15, 2016 Bad crack? Link to comment Share on other sites More sharing options...
landrvr1 Posted August 15, 2016 Share Posted August 15, 2016 There's no reason it shouldn't be working. Can I suggest that you start with a fresh scene for testing purposes? Link to comment Share on other sites More sharing options...
afkariaziz1 Posted August 15, 2016 Author Share Posted August 15, 2016 i did a new fresh scene and just use plane to check whether its working and it is working. idk what settings i touched on the bump map on the current scene. Link to comment Share on other sites More sharing options...
landrvr1 Posted August 15, 2016 Share Posted August 15, 2016 NICE! Can you just replace the water plane then? Is it working when you replace? Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted August 15, 2016 Share Posted August 15, 2016 Can you just delete everything but the water plane and post that scene here. I would like to review that. Link to comment Share on other sites More sharing options...
afkariaziz1 Posted August 15, 2016 Author Share Posted August 15, 2016 i started a new scene and everything was default. why is this not happening on my current scene? Link to comment Share on other sites More sharing options...
heni30 Posted August 15, 2016 Share Posted August 15, 2016 Just import everything into this file. Link to comment Share on other sites More sharing options...
afkariaziz1 Posted August 15, 2016 Author Share Posted August 15, 2016 i imported it into a new scene. still same though. Link to comment Share on other sites More sharing options...
heni30 Posted August 15, 2016 Share Posted August 15, 2016 No, I meant your isolated water object is working. So just import everything from the faulty scene into this scene minus the water object that isn't working. Link to comment Share on other sites More sharing options...
pablovergara Posted August 15, 2016 Share Posted August 15, 2016 ^yeah sometimes all you can do to solve a problem is delete the geometry causing the problem and model it again or even start a new scene and copy stuff over. I do that when I import models from revit. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
afkariaziz1 Posted August 15, 2016 Author Share Posted August 15, 2016 i have done what george said. it is working. idk what happen and how that works. something to do with the other scene materials or something. Link to comment Share on other sites More sharing options...
pablovergara Posted August 17, 2016 Share Posted August 17, 2016 ^good to know it's working now! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
