teresaplewa Posted August 14, 2016 Share Posted August 14, 2016 Hi guys! I have a problem with vray render elements. Im useing now new 3dsMax and Vray and suddenly they looks like that. Do you know why? What should I change so they look normal? Tanks in advance Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted August 15, 2016 Share Posted August 15, 2016 could you explain a little more your problem? That image is your RGB or lightpass?? Link to comment Share on other sites More sharing options...
teresaplewa Posted August 15, 2016 Author Share Posted August 15, 2016 Hi! Sorry for not beeing clear. This image is my Raw Global Illumination and Raw Lighting looks similar. RGB looks ok. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted August 15, 2016 Share Posted August 15, 2016 (edited) You don't need to be using the RAW render elements as they are meant for more complex set-ups when reconstructing the beauty pass. Use the non raw elements. https://docs.chaosgroup.com/display/VRAY3MAX/Beauty+%7C+RGB_Color+ Edited August 15, 2016 by Macker Link to comment Share on other sites More sharing options...
teresaplewa Posted August 15, 2016 Author Share Posted August 15, 2016 Yes I know that I dont need but I'm used to use also this Raw Global Illumination in Postproduction and I found it very helpfull. Just have no Idea why its like that suddenly and how to change it Link to comment Share on other sites More sharing options...
landrvr1 Posted August 15, 2016 Share Posted August 15, 2016 Yowza! I suspect this might be a bad material issue, but let's do some investigating. Have you tried turning off all the accessories - just leaving the architecture? Try doing a material override and make all the objects white. What happens then? Turn off all lighting but leave GI on. What's the result? Link to comment Share on other sites More sharing options...
teresaplewa Posted August 15, 2016 Author Share Posted August 15, 2016 It's funny- everything looks ok when i put one white material on objects. But when i put colored material its happenenig again... I made that project in older version of Max and then it was ok. Now I'm doing this render in newer version 2016 - I quess there's an issue somewhere... Link to comment Share on other sites More sharing options...
landrvr1 Posted August 15, 2016 Share Posted August 15, 2016 Hmm. It could very well be a bug, but I have a feeling it's not. What about just the architecture and nothing else? Did that look okay? The other thing to try is making all the accessories white, then see if the problem is there. Then try just the architecture as white. You'll narrow things down quickly at that point! Now that you know that when everything is white the problem goes away, you probably have a material problem. Maybe some odd AutoCAD or Revit material? Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted August 15, 2016 Share Posted August 15, 2016 are you using only VRay materials? I noticed that in the latest releases standard material do not create render passes. Also GI passes will skip self illuminated materials and very reflective materials such mirrows or glasses. Link to comment Share on other sites More sharing options...
Nic H Posted August 15, 2016 Share Posted August 15, 2016 have you tried using pflow to scatter billions of tiny lights over the entire scene to simulate bounced light Link to comment Share on other sites More sharing options...
maxarchivision Posted August 16, 2016 Share Posted August 16, 2016 remove "show samples" in "adaptive dmс" Link to comment Share on other sites More sharing options...
heni30 Posted August 16, 2016 Share Posted August 16, 2016 nicnic said: have you tried using pflow to scatter billions of tiny lights over the entire scene to simulate bounced light dude.........you need to take like a 6 months chill/hiatus in Bali/Thailand. You'll be good as new. Link to comment Share on other sites More sharing options...
landrvr1 Posted August 16, 2016 Share Posted August 16, 2016 heni30 said: dude.........you need to take like a 6 months chill/hiatus in Bali/Thailand. You'll be good as new. Haha. Who is that guy? Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted August 16, 2016 Share Posted August 16, 2016 Ninic is one of ours habitue, great artist that now lives in a Arch Viz retirement place trying to overcome his PTSD after too many years closelly working with Architects. Stay strong Ninic Link to comment Share on other sites More sharing options...
