Menno Posted December 1, 2004 Share Posted December 1, 2004 Hey, I've been fiddling around with a wall with different brick directions. Check image 1. They usually change the direction of the brick when above a door etc. It's a simple multi material with two composite materials (one for the front/back side and one for the left/right side (different tiling). The problem is the bump mapping. Wall2.jpg looks ok, but when I add the other bricks in, it just looks funky. Is there a solution to my problem (I'm not really experienced with mapping)? I just dragged the diffuse material to the bump map, check setup.jpg. BTW, don't mind the tiling Link to comment Share on other sites More sharing options...
