saeedsh Posted September 4, 2016 Share Posted September 4, 2016 Hi, I used to be a guest just reading threads at CGA, but I decided that I'd join the community. I'm an architecture student and been using v-ray for almost a year. here is my problem: I was experimenting and learning how to work with V-ray materials and so I was trying to create a material that would have some parts of it with a gloss finish while others are matt. So I tried to create an image similar to a bump map, however I wasn't sure where to put it... any advise from our respectful professionals? Thanks & Regards, Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted September 5, 2016 Share Posted September 5, 2016 I am not a Rhino user, so sorry if what I tell you can't be applied to you. I know VRay is very consistent throughout different software tho. If you need to control glossies with a map (B/W) you need to place it in the texture slot that is connected to the glossy values. Be sure of put a black color as base and adjust the transparency of you B/W texture to adjust the intensity of glossiness or you can adjust the overall brightness of the image in Photoshop before you use it in Rhino. Link to comment Share on other sites More sharing options...
