akshayarora Posted September 7, 2016 Share Posted September 7, 2016 Hello , I am using this photometric lights with IES , and Volume effect is on . But the issue is few of the lights are showing noise . Anybody know why they are reacting like this . Link to comment Share on other sites More sharing options...
akshayarora Posted September 8, 2016 Author Share Posted September 8, 2016 Any hint ?? Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted September 9, 2016 Share Posted September 9, 2016 what render engine are you using? Link to comment Share on other sites More sharing options...
akshayarora Posted September 11, 2016 Author Share Posted September 11, 2016 (edited) what render engine are you using? Vray 2.0 3Ds Max 2009 , but I have opened the scene in 3ds Max 2015 and Vray 3.2 also . Issue is same in both . Edited September 11, 2016 by akshayarora Link to comment Share on other sites More sharing options...
Chris MacDonald Posted September 12, 2016 Share Posted September 12, 2016 Well I suggest you update to the latest versions to see if the problem persists. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted September 12, 2016 Share Posted September 12, 2016 Perhaps its got something to do with the probabilistic lights checkbox? Try checking/unchecking that box and see if there is any change. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted September 12, 2016 Share Posted September 12, 2016 Perhaps its got something to do with the probabilistic lights checkbox? Try checking/unchecking that box and see if there is any change. I was thinking the same, but since it happens with the old version of V Ray too. then it got me not sure about that, but if you have the last version you should use that instead. Set the probabilistic light to the same amount of lights in your scene. Hopefully it work for you. Link to comment Share on other sites More sharing options...
akshayarora Posted September 13, 2016 Author Share Posted September 13, 2016 Thanks for the reply mentors , I also thought the same , I kept the probabilistic lights off , will try keeping them the same amount and will revert . Thanks Link to comment Share on other sites More sharing options...
Amen Posted September 14, 2016 Share Posted September 14, 2016 Have you checked, if they are scaled? That was my problem, they just did not work anymore, when they were scaled. Link to comment Share on other sites More sharing options...
