jeanchevallier Posted September 16, 2016 Share Posted September 16, 2016 Hello guys my name is Jean and i need help with a V-Ray problem i have made some 3D objects that i want to render to textures with V-Ray. i am using V-Ray with default settings and i'll apply a simple VRayMtl material But i get some weird textures and i can see some lines which should not be here. For informations i tried another render engine named Corona 1.4 and my textures are good so the problem is really with V-Ray, i tried to uninstall it and re install but it do not change anything. I'll add some picturures . Software: 3DS Max 2016 V-Ray 3.40.01 (Default settings) Windows 10 Pro 64 bit Link to comment Share on other sites More sharing options...
Devin Johnston Posted September 16, 2016 Share Posted September 16, 2016 Did you follow these render to texture guidelines? https://docs.chaosgroup.com/display/VRAY3MAX/Basic+Texture+Baking+with+V-Ray Link to comment Share on other sites More sharing options...
jeanchevallier Posted September 16, 2016 Author Share Posted September 16, 2016 Hello Davin, i been to try it and the problem is still here. http://screencast.com/t/Y1PeTr1uvK Link to comment Share on other sites More sharing options...
jeanchevallier Posted September 16, 2016 Author Share Posted September 16, 2016 I just been to try it Devin and the problem is still here Link to comment Share on other sites More sharing options...
Devin Johnston Posted September 16, 2016 Share Posted September 16, 2016 Do you have any co planer surfaces? Link to comment Share on other sites More sharing options...
jeanchevallier Posted September 16, 2016 Author Share Posted September 16, 2016 My object is placed in a box for the rendering, like on this screenshot. Its what you means Devin ? Link to comment Share on other sites More sharing options...
Devin Johnston Posted September 16, 2016 Share Posted September 16, 2016 Co planer objects are two pieces of geometry that share the same space, I can't tell from your images if this is the problem but you should check. Link to comment Share on other sites More sharing options...
jeanchevallier Posted September 16, 2016 Author Share Posted September 16, 2016 i been to check and no, there is not any Co planer, and today i tried to make a new object very simple like a cube with some extrudes and i got the same problem. Link to comment Share on other sites More sharing options...
jeanchevallier Posted September 16, 2016 Author Share Posted September 16, 2016 Devin, i think i have found the problem! i been to make a new 3dsmax scene and made a cube with extrudes again , then a unwrap and render to texture , and this time all was good ! I guess something was wrong with my first scene . And it was a old scene to be honest , so maybe it was the problem. I want to tank you very much for your help it was nice from you :-) Link to comment Share on other sites More sharing options...
