Interested in Reviewing an NEC Display?
Jeff Mottle
Hello all,
I'm crazy busy with travel until the end of the year, but NEC has reached out to me and is looking to see if we might be interested in doing a review of one of the displays in their latest release from the list below. Ideally someone from US/Canada/Latin America, but could be elsewhere if required. You can see some examples of previous reviews here: http://www.cgarchitect.com/features/category/reviews
If you're interested, shoot me an email at jmottle@cgarchitect.com
27-inch EA275WMi display with IPS panel
o sRGB gamut for online content development
o Designed for dual monitor configuration
o DisplayPort 1.2 inputs
o ControlSync technology, enabling users to control up to six displays in a multi-monitor configuration
o Smart sensing tech, which automatically detects work conditions to determine the proper display brightness with ambient light and human sensors
o SpectraView EA Kit available as option
· 27-inch EA275UHD display with IPS panel
o 3840 x 2160 4K Ultra-HD resolution
o 10-bit AH-IPS panel
o SpectraView compatibility
o DisplayPort 1.2
o UHD upscaling
o 163 DPI (dots per inch) of readability
o 6-ms response time
o Integrated 3-port powered USB 3.0 hub (1 up/3 down)
o ControlSync™ for multi-screen setups
o Human Sensor to reduce power consumption when the user is not present
· 21-inch P212 display with 4:3 aspect ratio
o Standard gamut display with IPS panel
o Used in digital image acquisition, command and control, and industrial apps
o Capable of 24x7 usage
o In medical environments, can be calibrated to DICOM standard for conformance
o Covers 97.9 percent of sRGB color space
o Internal 14-bit 3D programmable lookup tables
o SpecraView software available, ensuring accurate color without loss of detail because the adjustments are made in the monitor rather than the video card lookup tables
· 27-inch PA272 color critical display with SpectraView calibration software and sensor
o Built on GB-R LED backlights
o 2560 x 1440 resolution
10-bit wide color gamut AH-IPS LCD panel
o MultiProfiler software, which provides easy-to-use control over most display settings
o 10-bit active matrix AH-IPS panel with GB-R backlight and no-sparkle, antiglare coating
o 2560 x 1440 resolution at 109 PPI
o 350 cd/m² brightness and 1000:1 contrast ratio at 37 percent less power than CCFL
o Near perfect (99.3 percent) coverage of Adobe RGB and 100 percent of sRGB color space
o Internal 14-bit programmable 3D lookup table (LUT)
