pavement Posted December 3, 2004 Share Posted December 3, 2004 I'm trying to apply a multi-sub object material to a loft, and i'm having some problems with the road texture. here is the texture to apply to the road and the result: http://www.pedro.silva.name/loft.htm I assigned a material id to the segment of the road. The left part of the road hasnt the white line of the texture. Why is that? Thx in advance, Pedro Link to comment Share on other sites More sharing options...
BSArch98 Posted December 3, 2004 Share Posted December 3, 2004 Pedro, The reason the white line is only showing up on one side is that your texture is being wrapped completely around your loft object. Basically a cylindrical UVW map that follows the path of the loft. You will have to adjust the tiling in order to see the other white line. Either in the loft "surface parameters" roll-out (adjust the width repeat) or in your material change the repeat on the texture itself. Either of those should work for you after a couple tries. Chris Link to comment Share on other sites More sharing options...
pavement Posted December 3, 2004 Author Share Posted December 3, 2004 It worked, thx a lot Pedro Link to comment Share on other sites More sharing options...
