branskyj Posted November 2, 2016 Share Posted November 2, 2016 Hi all, Do you think it's possible to use Photoshop or other program to batch convert multiple RAW files into JPEGs considering it's not just the conversion that is needed but also some changes to Exposure, Contrast and so on applied to each image? I have a whole bunch of overexposed images which I need to fix. What I currently do is- I bring a RAW file into Photoshop, tweak some of the settings (Exposure, Contrast) in the initial dialog window, Save the settings in an .xmp file. Then I use that file to apply the same tweaked settings to each subsequent RAW file. I tried recording an Action in Photoshop ( I recorded the process of opening the RAW file and changing the Exposure) but that only partially worked and didn't really save that much time since manual input on my part was still needed. Many thanks for any help. Link to comment Share on other sites More sharing options...
Nic H Posted November 2, 2016 Share Posted November 2, 2016 id use lightroom for this Link to comment Share on other sites More sharing options...
branskyj Posted November 2, 2016 Author Share Posted November 2, 2016 id use lightroom for this Thanks for that, so that's definitely possible with Lightroom? I ask because I've never used it... Link to comment Share on other sites More sharing options...
numerobis Posted November 2, 2016 Share Posted November 2, 2016 (edited) +1 for lightroom You can copy/apply the changes to any number of images and you have the direct visual control and can change additional values. Edited November 2, 2016 by numerobis Link to comment Share on other sites More sharing options...
branskyj Posted November 2, 2016 Author Share Posted November 2, 2016 Much appreciated, guys. I will give that a try tonight. Have a good one Link to comment Share on other sites More sharing options...
SkylineArch Posted November 2, 2016 Share Posted November 2, 2016 Use File > Automate > Batch, or File > Scripts > Image Processor in Photoshop Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted November 2, 2016 Share Posted November 2, 2016 Bridge does this too.... It is all the same, but Bridge will allow you to use camera raw to adjust the images and them copy/paste those setting onto any or all of the other images before they are batch processed. Link to comment Share on other sites More sharing options...
branskyj Posted November 3, 2016 Author Share Posted November 3, 2016 Thanks guys, I gave Bridge a try and it worked flawlessly. Here's a link to the video that shows how it's done: All the best. Link to comment Share on other sites More sharing options...
joneytran Posted November 28, 2016 Share Posted November 28, 2016 File > Scripts > Image Processor in Photoshop Link to comment Share on other sites More sharing options...
