Sho-Time1 Posted November 9, 2016 Share Posted November 9, 2016 Greetings all. Im working on a project in which a disco ball will be located in the middle of the scene.. does anybody have suggestions on how to create the disco ball and the effect of light bouncing around the room? I'm not having very much luck...any comments or suggestions are appreciated. Link to comment Share on other sites More sharing options...
heni30 Posted November 9, 2016 Share Posted November 9, 2016 TurboSquid has about 50 different ones for sale. Link to comment Share on other sites More sharing options...
Sho-Time1 Posted November 9, 2016 Author Share Posted November 9, 2016 Thanks, More so looking to create it myself...without paying. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted November 9, 2016 Share Posted November 9, 2016 Physics my friend. Yo need to create a ball with flat faces as mirrors. Not a default perfectly rounded sphere as Max by default will do. Create a sphere, not many subdivisions. then transform to edit poly, then erase all smooth groups on it, you'll see the sphere will look faceted (this is good in this case) then you could extrude or bevel all the faces and give a mirror material to it, all the other parts of the sphere should not be reflective, this will simulate the many flat pieces of glass that made a disco ball. You could add a small noise modifier too to create more variation between the angle of the faces. Point your light to the sphere, you should use spot lights, or directional area lights not regular rectangle light, you don't want a even illumination you need a focused illumination. then activate caustics and you are ready to go Link to comment Share on other sites More sharing options...
Sho-Time1 Posted November 10, 2016 Author Share Posted November 10, 2016 You are the man! Link to comment Share on other sites More sharing options...
Chris MacDonald Posted November 10, 2016 Share Posted November 10, 2016 We used caustics to animate this effect once - it looked brilliant. Highly recommend doing it that way. Link to comment Share on other sites More sharing options...
kriskar Posted November 16, 2016 Share Posted November 16, 2016 Awesome suggestion Francisco! I was wondering how to create a disco ball effect a while back. Thanks for the explanation! Link to comment Share on other sites More sharing options...
