Chris MacDonald Posted December 5, 2016 Share Posted December 5, 2016 Hey guys, I've got an issue that I've never had before in previous max versions. Basically I have a scene that has been set up in millimeters and referenced into that is a scene set up in centimeters. Previously this has never been an issue. This time however max has referenced the scene as you would expect - all of the buildings and such are at the correct scale, but none of the mapping is. It's all 10x too big. Has anyone else experienced this? Link to comment Share on other sites More sharing options...
TomD_Arch Posted December 5, 2016 Share Posted December 5, 2016 I've seen scaling/ mapping issues happen when the model you are importing in is revit. You can fix it by setting your units to feet from inches. Don't know if this applies to your situation??? Link to comment Share on other sites More sharing options...
Chris MacDonald Posted December 6, 2016 Author Share Posted December 6, 2016 The geometry is all modeled in max, there doesn't appear to be any rhyme or reason behind it other than it's a new version of max. Link to comment Share on other sites More sharing options...
