julienfrd Posted December 7, 2016 Share Posted December 7, 2016 Hi all, I'm using Vray to render a scene, I usually don't have problems with day lighting, but this scene is quite dark and have a lot of small lights (spots, vray lights, and a vray sky with low intensity). I don't know why, but I have a lot of noise. The strange thing is that if I only render a region, there is no noise... Any idea about the reason and how to solve it? I attach a capture where you can see the noise and "no noise" if render region, + vray settings. Thanks in advance. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted December 7, 2016 Share Posted December 7, 2016 You are rendering with Progressive. A region running for a minute gets more passes than a full image. Let the full image render for a lot longer. You can always stop it if you are happy with it before its complete. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted December 8, 2016 Share Posted December 8, 2016 Corey si correct, I also would reset all VRay settings to default, your settings seems like very low, this will give fast feedback for testing but not usable for Final render. You LC is way too low, if you have a few lights, your GI need to increase. Link to comment Share on other sites More sharing options...
julienfrd Posted December 9, 2016 Author Share Posted December 9, 2016 Hi Corey, Francisco, Sure, in adaptive, all ok, thanks. But why does the progressive rendering stops instead of increase quality if I don't stop it by myself? (the low quality settings, yes, it's just for testing ) Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted December 9, 2016 Share Posted December 9, 2016 Because you have a time limit set to 1 minute. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted December 9, 2016 Share Posted December 9, 2016 julienfrd said: Hi Corey, Francisco, Sure, in adaptive, all ok, thanks. But why does the progressive rendering stops instead of increase quality if I don't stop it by myself? (the low quality settings, yes, it's just for testing ) Please refer to the VRay manual, there explain in detail how progressive rendering works. in a nut shell you can setup quality Vs Time. IF you need quick rendering, you setup the time, if you ultimate goal is quality then you setup passes. Link to comment Share on other sites More sharing options...
julienfrd Posted December 10, 2016 Author Share Posted December 10, 2016 Ok, it was easy, sorry for the newbie question..! Very nice, the progressive mode Thank you! Link to comment Share on other sites More sharing options...
