hoseinasadi Posted December 12, 2016 Share Posted December 12, 2016 Hey guys, Recently I've been trying to start working on an old project. After hitting the render button all I get is a black screen and two errors in the v-ray messages box. I'm not sure why is this happening, weird part is that when I use the vray RT it works just fine! any suggestions? Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted December 13, 2016 Share Posted December 13, 2016 What happens when you render without setting it to save? Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted December 13, 2016 Share Posted December 13, 2016 I can not remember why this happens, but I've seen it before, I think you need to put a path that you can find in your hard drive, on the Max output, not the VRay output. no need to save there ,jut put the path. Then un-check the save one the VRay output. Also check the passes path, there you can just delete anything they have. Do a test rendering, then set your save path as usual on VRay. Link to comment Share on other sites More sharing options...
hoseinasadi Posted December 13, 2016 Author Share Posted December 13, 2016 Thanks guys. turns out it was the issue with vray output path, simply relinked the output path in vray for both final image and vray elements and bam! I had a render. Link to comment Share on other sites More sharing options...
