muzaffarkhan Posted December 15, 2016 Share Posted December 15, 2016 hello everyone, i just rendered this, in theceiling cove lighting you can see those lines are pixeled, i mean those are not straight and neat, whats wrong? Link to comment Share on other sites More sharing options...
Chris MacDonald Posted December 15, 2016 Share Posted December 15, 2016 Spooky. Never seen that before, and you definitely won't find any information about it by using forum search or google. Link to comment Share on other sites More sharing options...
muzaffarkhan Posted December 15, 2016 Author Share Posted December 15, 2016 that problem is in many of my rendering, how do i solve it??? Link to comment Share on other sites More sharing options...
Shahid Ansari Posted December 15, 2016 Share Posted December 15, 2016 1- Vertical Shift is not Correct 2-Make Light Invisible 3-Increase Subdivision and also check in high resolution Render I think will Fix Link to comment Share on other sites More sharing options...
muzaffarkhan Posted December 15, 2016 Author Share Posted December 15, 2016 1. whats vertical shift? 2. that's emissive, how do I make it invisible? 3. will try this. Link to comment Share on other sites More sharing options...
dontorino Posted January 4, 2017 Share Posted January 4, 2017 Vertical shift is little button in Vrayphysical camera options, it will make your vertical lines straight, you should always use it unless your camera isn't looking at some weird downward angle.About your pixelated ceiling light, it's because it is very overexposed, make the light smaller, or reduce intensity, or move it further away from the geometry. Link to comment Share on other sites More sharing options...
muzaffarkhan Posted January 5, 2017 Author Share Posted January 5, 2017 sorry but i am not able to find any VERTICAL SHIFT option or button in vray setting, please help. Link to comment Share on other sites More sharing options...
dontorino Posted January 5, 2017 Share Posted January 5, 2017 sorry but i am not able to find any VERTICAL SHIFT option or button in vray setting, please help. Select Vrayphysicalcamera..and there is a button called "Guess Vert". Link to comment Share on other sites More sharing options...
muzaffarkhan Posted January 6, 2017 Author Share Posted January 6, 2017 these are the options i get in vray physical camera. Link to comment Share on other sites More sharing options...
paragchaudhari1 Posted January 6, 2017 Share Posted January 6, 2017 you need to use v-ray camera to use 'Guess Vert' option. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted January 6, 2017 Share Posted January 6, 2017 You might want to let people know that you are using Vray for Sketchup next time. Link to comment Share on other sites More sharing options...
