Windows 10 - Re-boot. How to Stop.
neil poppleton
  • 2 weeks later...
  rsuleyman said:
If they're rebooting because Windows is installing updates then the only solution I found was to switch on the metered connection option in the network settings. This makes Windows think that you have a data limit so it won't download updates automatically.
Rico
Hi Rico, This only seems to work for wi fi network connection. Have you a found a way to adjust when not on a wi fi connection, thanks.
I've only tried it on a wifi connection. It seems as though it's possible to do it an ethernet connection as well but it's a bit more complicated.
Here's a link to a step-by-step guide I found:
https://www.cnet.com/uk/how-to/meter-your-ethernet-connection-in-windows-10/
It looks fairly straightforward but it does involves editing the registry so make sure you know what you're doing before you attempt it.
