oyie Posted December 6, 2004 Share Posted December 6, 2004 hi im new in vray, i need some advised on my rendering, it seems that when i render in vray some of my reveal lines dissappeared.thanks in advanced Link to comment Share on other sites More sharing options...
archkre Posted December 6, 2004 Share Posted December 6, 2004 To tell you something you should upload your mesh to take a look at it! Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted December 6, 2004 Share Posted December 6, 2004 try uping your anti-aliasing, if that doesn't work, try increasing the number you are using for 'dist thresh'. both will increase render times, the second more so than the first. Link to comment Share on other sites More sharing options...
Chad Warner Posted December 6, 2004 Share Posted December 6, 2004 The other thing to look at is whether or not you are rendering at your final resolution. I have problems like this from time to time, but as soon as I render hi-res, it goes away. -Chad Link to comment Share on other sites More sharing options...
oyie Posted December 6, 2004 Author Share Posted December 6, 2004 {here's my mesh daniel. {travis i tried youre advice but i still got the same result. thanks anyway Link to comment Share on other sites More sharing options...
Christopher Nichols Posted December 6, 2004 Share Posted December 6, 2004 try using the simple two level AA, instead of the adaptive... first at the default setting of 1-4, then raise it to 2-4. If you want to use adaptive try doing a 0,2 setting then a 1,2 setting Link to comment Share on other sites More sharing options...
oyie Posted December 6, 2004 Author Share Posted December 6, 2004 thanks Christopher, ill try youre advice Link to comment Share on other sites More sharing options...
