cullen Posted December 6, 2004 Share Posted December 6, 2004 I'm having to write a lisp routine for a client that will change a number of drawing variables at once. I've got everything to work correctly except the dimscale. Does anyone happen to know the code to set a certain dimstyle current? I've been looking everywhere. Thanks, crw Link to comment Share on other sites More sharing options...
cullen Posted December 6, 2004 Author Share Posted December 6, 2004 I figured it out... Incase any of you are wondering how to do this as well. you have to put a "-" infront of the word dimstyle. This will make it run from the command line instead of the dialog box. here's an example: (defun COMMAND HERE () (command "-AECDWGSETUP""SC""12""1/8\"""4'-0\"""") (command "-DIMSTYLE""R""DIMSTYLE HERE") Hope that helps somebody:D crw Link to comment Share on other sites More sharing options...
