drawing abbreviations
ninamaxwell
Hi All
Just came across this forum and hope that I can find the answers here to the information stated in the drawing (metric) attached please. Starting from the bottom:
EL = Existing Level?
FFL LEVEL = Floor Finish Level? what is +43.060 means, when Existing Level is +2.71?
Thank you in advance.
Nina
Hi Nina,
quick one. To me this simply reads that the +43.060 is an actual datum level and that the +2.71 is an abbreviated datum level.
If you work out the values of the actual datum levels ground to first, the level should give you the same as +2.71
I hope this helps?
Cheers
