Brodie Geers Posted January 12, 2017 Share Posted January 12, 2017 Checking to see if this is a universal bug. In 3ds Max 2015 when I'm in an Editable Mesh and go into Edge mode and click on Slice Plane, I don't get the yellow slice plane preview to show me where the slice plane is and what it's orientation is. I believe this is true for other versions of Max as well and it's a basic enough function that it drives me nuts. Am I missing something here? Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted January 12, 2017 Share Posted January 12, 2017 Yep that happens always if you are using editable mesh, if you put a edit polygon in top, then you'll see the yellow gizmo and a redish line where the cut is going... one of those things... Link to comment Share on other sites More sharing options...
Josef Wienerroither Posted January 16, 2017 Share Posted January 16, 2017 Strangely enough, it works in "Edit Mesh" modifier too, so in cases where "Edit Poly" does not work, apply a Edit Mesh modfier. Note: Edit poly does not support all mesh topology without splitting some vertices etc . Thats especially true for complex T-type edge junctions. And it only happens in Nitrous mode, so it seems to be some glitch in the Editable Mesh slice gizmo drawing code Anyone of you ever reported this ? Autodesk is most propably even not aware of the issue Always report. I did now, but would be good if you do the same ... Link to comment Share on other sites More sharing options...
Brodie Geers Posted January 17, 2017 Author Share Posted January 17, 2017 I probably should report it. To be honest, I run into so many bugs and crashes with Max that it's demoralized me to reporting bugs anymore as it would take up a notable portion of my work day. I thought this was was worth asking about just because it seems like such a basic feature, and I believe this bug has persisted through several generations of the software, that I must be missing something. Link to comment Share on other sites More sharing options...
Josef Wienerroither Posted January 18, 2017 Share Posted January 18, 2017 Yeah, I too could'nt remember if we ever got the slice plane visible in editable mesh ( i know it being the case of edit poly) But testing back the Max versions i learned that the bug appear first in Max 2015. What i know is that we never got a PREVIEW of the sliced geometry in edit/edtiable mesh. But i can assure you that bug reporting IS important. Sometimes one has to be persistent though and being eg. on the beta (and report directly) helps a lot too Link to comment Share on other sites More sharing options...
alexeistuckov Posted January 24, 2017 Share Posted January 24, 2017 thanks Link to comment Share on other sites More sharing options...
