Vince Paske Posted February 7, 2017 Share Posted February 7, 2017 Ever since the SP3, Max 2017, the Tilt correction in the physical camera display fades on and off. This happens with Auto Vertical correction and when you manually set it. It renders with the tile correction on, it only happens in the viewport regardless of what type of settings its on (high quality, standard, performance...). It's annoying to have other people look at your view to verify the perspective, and then the verticals start shifting to diagonals, then back to straight up again over and over. I've also updated the drivers for my gtx 980 several times during the course of this weirdness. Anyone else having this issue? Link to comment Share on other sites More sharing options...
James Vella Posted February 7, 2017 Share Posted February 7, 2017 check if it still happens if u turn off progressive View > Progressive Display Link to comment Share on other sites More sharing options...
lautarovogel Posted February 8, 2017 Share Posted February 8, 2017 I had the same issue with max 2016, but it only happened when "enable DOF" was on. Are you using DOF in that camera? Link to comment Share on other sites More sharing options...
Vince Paske Posted February 8, 2017 Author Share Posted February 8, 2017 Turning off progressive did the trick - thanks! Link to comment Share on other sites More sharing options...
James Vella Posted February 8, 2017 Share Posted February 8, 2017 youre welcome Link to comment Share on other sites More sharing options...
ramon acha Posted February 9, 2017 Share Posted February 9, 2017 youre welcome Eternal gratitude for this!! I've been feeling dizzy because of those camera fades for months Link to comment Share on other sites More sharing options...
jorgegomez2 Posted October 12, 2017 Share Posted October 12, 2017 I have the same issue on max 2016, the first frame renders fine, but all the others lose the perspective correction. HEEELP Link to comment Share on other sites More sharing options...
