Marco Manunta Posted February 17, 2017 Share Posted February 17, 2017 Hello guys, check this image please: http://imgur.com/a/1vgKg i ve a scale/viewport problem specially with sketchup imported files. If in the viewport i m far, it looks good. If i zoom in, the surfaces of the model are overlapping and it's so weird. i work in meters, i export in meters, but in order to work on the model in 3DS max in a clean way, i m forced to use the viewport clipping all the time. the only time it works, is when i import the 3ds file without checking Convert Units. But strangely the model will not be at the correct size. I would have to scale it up a lot. So what i m trying to ask you folks is: how can i export from SU and import in 3DS, maintaining the right size of the model and a clean viewport too? Thanks! Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted February 17, 2017 Share Posted February 17, 2017 Reset xform usually works on this kind of wonky geometry. Link to comment Share on other sites More sharing options...
jackbird Posted February 17, 2017 Share Posted February 17, 2017 Sketchup Geometry sometimes also needs some Edit Normals modifier voodoo - IIRC the incantation is Subobject > Select All > Reset > Collapse Modifier Link to comment Share on other sites More sharing options...
