nealewan Posted February 18, 2017 Share Posted February 18, 2017 hello guys i am a new member and really need your help..i have this problem with my vray lights in 3dsmax. i am trying to lighting the interior of the model shown in the image with yellow lights as shown in the light settings on the right. but after each test render the colour comes out red. i have a spherical light inside the space and a plane light facing out all with the same settings. for GI primary engine is brute force and secondary light cache vray also give a warning ..invalid light cache sample...i dont really know if its the cause or how to fix it. thanks a lot Link to comment Share on other sites More sharing options...
Victor Erthal Posted February 19, 2017 Share Posted February 19, 2017 that seems odd. have you tried using the color mode instead of temperature mode? Link to comment Share on other sites More sharing options...
Sho-Time1 Posted February 19, 2017 Share Posted February 19, 2017 Is your light temperature set to 200? That will give you red results even though it doesn't appear red in the small preview box below. Try 3500 is typically deep orange up to 9000 is deep blue. I typically never go outside of that range. Link to comment Share on other sites More sharing options...
nealewan Posted February 19, 2017 Author Share Posted February 19, 2017 (edited) yes thanks for your suggestion...i tried the colour mode and it worked fine....i was just worried why the colour kept turning out incorect. thanks Edited February 19, 2017 by nealewan Link to comment Share on other sites More sharing options...
nealewan Posted February 19, 2017 Author Share Posted February 19, 2017 owh really!...owh thats good to know...i would stick to the values you suggested...thank you vry much Link to comment Share on other sites More sharing options...
nealewan Posted February 19, 2017 Author Share Posted February 19, 2017 Is your light temperature set to 200? That will give you red results even though it doesn't appear red in the small preview box below. Try 3500 is typically deep orange up to 9000 is deep blue. I typically never go outside of that range. owh really!...owh thats good to know...i would stick to the values you suggested...thank you vry much Link to comment Share on other sites More sharing options...
