amandawong Posted February 21, 2017 Share Posted February 21, 2017 Hello, I have a problem when using Floor Generator to create the floor. I'm using 3ds Max 2017 and after I added the floor generator as a modifier, the spline disappeared. I actually attached 2 separate spline into one. Could anyone give some advice on this? I'm new to max. Thank you. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted February 21, 2017 Share Posted February 21, 2017 ...The spline is still there, underneath floor generator in the modifier stack. Link to comment Share on other sites More sharing options...
amandawong Posted February 21, 2017 Author Share Posted February 21, 2017 (edited) I know the spline is there, but it suppose to have the floor generated after I applied the modifier. Edited February 21, 2017 by amandawong Link to comment Share on other sites More sharing options...
Chris MacDonald Posted February 21, 2017 Share Posted February 21, 2017 Have you checked that it is a closed spline? Link to comment Share on other sites More sharing options...
amandawong Posted February 21, 2017 Author Share Posted February 21, 2017 (edited) I think so, I combined 2 splines using Attach, then weld the vertexs Edited February 21, 2017 by amandawong Link to comment Share on other sites More sharing options...
Chris MacDonald Posted February 21, 2017 Share Posted February 21, 2017 Are they overlapping? This can cause issues. Keep the splines separate then copy & paste (instanced) the modifier from one to the other, so that all the settings stay the same (which I assume is what you want). Link to comment Share on other sites More sharing options...
amandawong Posted February 22, 2017 Author Share Posted February 22, 2017 I think its really about the 2 splines didnt merge well, I'm not sure why, but I created the same shape with Line and it works. Thanks Chris Link to comment Share on other sites More sharing options...
