3ds Max Vray 3.5 Toon line not working
Randy liddil
So I have a 3ds Max file where I'm rendering a plan view using Vray toon. I have a standard camera with "orthographic projection" turned on to render the plan view and Vray exposure in exposure control. The problem now is that when I render the plan view the Vray toon no longer shows up after updating to Vray 3.50.03.
Anyone know of a way to render a plan view with Vray toon in a Vray physical camera? there is no "orthographic projection" in the Vray camera.
Just noticed that since the new 3ds max has it's own "physical camera" there are a couple of things you can't do anymore.
1.) You can't use this script to make the camera render an Orthographic View (http://www.scriptspot.com/3ds-max/scripts/vray-orthographic-rendering-camera-rig).
2.) You can't render any kind of elevation in 3ds max with a Vray Toon outline.
3.) You can no longer use a Standard Camera with Vray exposure control when trying to render a Vray Toon Line effect with the new Vray 3.5
Edited by liddil101
  • 2 weeks later...
Hi Randy,
I'm able to use a standard camera in ortho mode with vray camera exposure and vray toon. I'm using Max 2016 with Vray 3.50.03.
I use pixels and not world in vraytoon parameter settings, maybe that's the issue?
Edited by shaunph78
added screenshot of settings
