yellow dots in my vray rendering... help!
rohitre
I think you are interpolating your GI, I am guessing you are using Irradiance and light cache?, try to go with default values, maybe try brute force in your first bounce and if problem persist, then it may be material problem.
Having said that your over all colors and material should be a tone softer, do not use 100% color intensity, make it 80% yellow, the floor also is too bright.
I see you are using Linear color mapping, try with Reinhardt and set it up to 50% or 40%.
all those over bright/burned areas should go away.
